This article will guide you through connecting MS Access to Stripe using the ZappySys ODBC API Driver for data retrieval. The ZappySys SSIS Stripe Connector provides a robust solution for seamlessly integrating your Stripe data, making it easier to manage and analyze your information across various applications.
- Stripe Account
Connect to Stripe
First, refer to this article for detailed instructions on connecting to Stripe with the ZappySys ODBC API Driver.
Read Data in Microsoft Access
Open MS Access and create a new database.
Under External Data, create a New Data Source, select Other Sources, and then select ODBC Database.
Choose the option Import the source data into a new table in the current database.
Navigate to the Machine Data Source, select the data source you created earlier, and click OK.
Proceed with selecting tables and views. You can import multiple tables or views:
Wait for the data to load. Once complete, you should see a similar view:
Using Linked Tables for Live Data (Slower Performance)
Linked tables in Microsoft Access are essential for online databases as they allow real-time access to centralized data, support scalability, enable collaboration, enhance security, and simplify maintenance tasks. They offer a flexible and efficient way to work with data stored in online databases, promoting cross-platform compatibility and minimizing data duplication.
Create a new database. Then, under External Data, create a New Data Source, select Other Sources, and then select ODBC Database. This time, choose the option Link to Data Source by creating a linked table.
Proceed with selecting tables and views. You can link multiple tables or views:
When prompted to select the Unique Key column, DO NOT select any column(s) and click OK.
Finally, double-click the newly created Linked Table to load the data:
Save your authentication details to avoid needing to retrieve them each time you connect.
Following these steps, you can easily connect MS Access to Stripe using the ZappySys ODBC API Driver, streamlining the data integration and retrieval process. This powerful tool simplifies the management of your Stripe data, enabling enhanced analysis and reporting. If you encounter any issues or require further assistance, our support team is available via chat on our website.
For more detailed information, refer to our ZappySys Stripe Connector.
