When making a call to REST or SOAP API you may encounter this error:
Error: System.Net.WebException: The remote server returned an error: (403) Forbidden.
Possible cause
There can be several causes for this:
- You provided the wrong authentication credentials, e.g.:
- HTTP username or password
- API key
- Access or Refresh Token, etc.
- Windows Server OS is configured to use less-than
TLS 1.2protocol
In SSIS package
If you are calling an API in SSIS package, make sure you are parameterizing sensitive data, i.e. authentication data like the password, API key or Refresh Token.
In rare cases, you may be getting this unrelated
Forbidden (403)when the component failed to establish a secure TCP channel. In that case, you may test it by calling this PowerShell command:(Invoke-webrequest -URI “https://your-api.com/api/action”).Content
If you get a TLS-related error, it means, it’s a hidden TLS issue. Solve it by:
- Enabling
TLS 1.2or above protocol in Windows Server OS - Setting
TLS v1.2 or higheroption in SSIS connector:
In API Source or API Destination look for TLS parameter after checking
Show Advanced Parametersoption. - Enabling
In ODBC data source
If you are calling it in ODBC data source, double-check that the credentials are set correctly.
- Enabling
TLS v1.2 or higheroption in ODBC data source:
In API Connector-based data source look for TLS parameter after checking
Need more help?
If the above steps did not help, contact our support team via chat on our website.
