The ZappySys Logging Task is a free SSIS task that writes custom messages, including SSIS variable values, to a message box, the SSIS log, or a file. This article shows how to log variable values and errors without writing code.
When to use the Logging Task
- You want to check variable values while building a package, without writing a Script Task.
- You need to record values such as row counts or file names for each run.
- You want a readable error message when a package fails.
Open the SSIS Variables pane (SSIS > Variables) and create two variables:
User::FileName(String) with the valueC:\Data\Customers.csvUser::RowCount(Int32) with the value250
Drag the ZS Logging Task from the SSIS Toolbox onto the Control Flow and double-click it to edit.
Set the logging mode to show a message box.
Enter the message. Type each variable name inside double curly braces, and the task replaces it with the value at runtime:
File: {{User::FileName}} Rows loaded: {{User::RowCount}} Package: {{System::PackageName}} -
Click OK to save the configuration.
Right-click the task and select Execute Task. A message box shows the message with the variable values.
Logging to the SSIS log or a file
A message box waits for a click, so use it only while developing. For packages that run on a schedule, change the logging mode:
- SSIS log: messages appear in the Progress tab in Visual Studio and in the SSIS catalog reports on the server.
- File: enter a path such as
C:\Logs\LoadCustomers.log. The account that runs the package needs write access to the folder.
Logging errors
Open the Event Handlers tab, select the package, select OnError, and click the link to create the event handler.
Drag a Logging Task onto it, set the logging mode to write to a file, and enter this message:
Package {{System::PackageName}} failed. Task: {{System::SourceName}} Error: {{System::ErrorDescription}}
The Logging Task writes messages with variable values to a message box, the SSIS log, or a file, for free and without code. Use the message box while developing, and the SSIS log or a file for scheduled runs and error logging.
If you need assistance using the Logging Task, please get in touch with our support team:
