SSIS tutorial: How to fix SharePoint error 400 and 500 related to datatypes
In this post, we will see how to fix the two most common errors related to sending bad data or missing required data when writing to the SharePoint API.
(400) Bad Request - invalidRequest
During the Insert / Update (POST or PUT) operation, if you did not supply an OData Type for Multiselect Datatype, then you may see the following error.
Response Body: {“error”:{“code”:“invalidRequest”,“message”:“Invalid request”,“innerError”:{“date”:“2025-11-17T20:48:54”,“request-id”:“b30b17b0-2a98-4024-98db-5f159f59495d”,“client-request-id”:“b30b17b0-2a98-4024-98db-5f159f59495d”}}}
—> System.Net.WebException: The remote server returned an error: (400) Bad Request
How to fix in SSIS
To fix this error in SharePoint Online ODBC Driver, supply a static value for the ODataType column as below
How to fix in ODBC
If you are using the ZappySys API Driver for SharePoint and you get a similar error, then make sure to pass the same field value as below.
UPDATE  "Travel Requests" --list name
SET
	 Title='MyTitle @ <<FUN_NOW>>'
	--Choice Multi-Select
	, CustomChoiceMulti = '["AA", "BB"]'
	, CustomChoiceMultiODataType='Collection(Edm.String)' --for multi select must supply OData Type
	--Lookup
	--field with Lookup type must be set to [<field-name>LookupId] field (suffix with LookupId)
	, CustomLookupSingleLookupId = 1
	--Lookup Multi-Select
	, CustomLookupMultiLookupId = '[1,3]' --for multi select must supply OData Type
	, CustomLookupMultiLookupIdODataType='Collection(Edm.Int32)'
	--Person
	,CustomPersonLookupId = 11
	--Person Multi-Select
	, CustomPersonMultiLookupId = '[11, 22]'
	, CustomPersonMultiLookupIdODataType='Collection(Edm.Int32)'
Where Id=1 --List Item Id
--- Insert Example ----
INSERT INTO "Travel Requests" --list name
	 Title
	, CustomChoiceMulti
	--Person
VALUES(
	, '["AA", "BB"]'
	, 'Collection(Edm.String)' --for multi select must supply OData Type
	--Lookup
	,  1
	, '[1,3]' --for multi select must supply OData Type
	, 'Collection(Edm.Int32)'
	--Person
	,11
	, '[11, 22]'
(500) generalException
You may also get a slightly different error like this.
“error”: {
“code”: “generalException”,
“message”: “General exception while processing”,
“innerError”: {
“date”: “2025-11-17T21:35:29”,
“request-id”: “e8e05b88-0013-435b-8d8d-cc64930792bd”,
“client-request-id”: “e8e05b88-0013-435b-8d8d-cc64930792bd”
How to fix in SSIS
Make sure you do not map bad datatypes. Example: If you mapped Int32 type to a string field, then change to String → String.
How to fix in ODBC
For the ODBC Driver, use a string type when the target field is a string.
Bad SQL Example
INSERT INTO MyList(SomeText) VALUES(1234)  --//sending number in string field causes error, must be quoted to treat as string
Good SQL Example
INSERT INTO MyList(SomeText) VALUES('1234')  --//quote number to treat as string
