SSIS Tutorial: Converting Excel to PDF using Adobe APIs
In this guide, we will walk through the process of converting an Excel file into a PDF using Adobe APIs within an SSIS package. This involves setting up an OAuth connection, uploading the file, converting it to PDF, and retrieving the converted document.
SSIS PowerPack: Download and install the ZappySys SSIS PowerPack
Get Credentials for Authentication of Adobe PDF Services, follow Adobe PDF Services API documentation
Step-by-Step Guide
Let’s jump right in, step by step, as we learn how to create a PDF file from an Excel Sheet using Adobe APIs in SSIS.
  2. Once you have finished the first step, Open Visual Studio and Create a New SSIS Package Project.
  3. Now, follow the steps below to achieve our requirement.
Step 1: Create OAuth Connection
To authenticate with Adobe APIs, we need to establish an OAuth connection using the client credentials.
  1. Right click in the Connection Manager panel and click on New Connection
  2. Select ZS-OAUTH Connection Manager from the Connection Managers list and Click on Add Button.
  3. Configure new OAuth Connection for Adobe PDF Services as below, Set OAuth Provider to Custom and OAuth Version to OAuth2 .
  4. Select Client Credentials Grant as the OAuth Grant Type.
  5. Enter the Client ID and Client Secret.
  6. Set the Access Token URL to https://pdf-services.adobe.io/token. I’m using https://ims-na1.adobelogin.com/ims/token/v3 .
  7. Add the required Scopes/Permissions (e.g., openid , AdobeID , DCAPI ).
  8. Save and test the connection.
Step 2: Upload Pre-Signed URL
Before uploading the Excel file, obtain a pre-signed URL from Adobe APIs.
  1. From the SSIS Toolbox look for items starting with “ZS”. Drag and Drop [ZS Rest API Task] to Designer Surface.
  2. Configure the Request Settings tab Request URL Access Mode to URL from connection.
  3. Select the Adobe OAuth connection created earlier.
  4. Set the Request Method to POST.
  5. In the Body (Request Data) section, specify the media type:
{"mediaType": "application/vnd.openxmlformats-officedocument.spreadsheetml.sheet"}
  1. In the Headers section, add X-API-Key with your Adobe API key.
  2. Now, Configure the Response Settings tab to capture important information from the API response.
    :white_check_mark: Key Configuration Settings:
    • Response content type: Json
    • Response Filter Expression: $
      (This retrieves the entire JSON response)
    • Continue on filter error: unchecked
    • Save Mode: Save to Variable
    • Select Variable: User::varURIWithAssetID
      (This captures the URL with the Asset ID returned by the API)
  3. Execute the task to get the pre-signed URL.
Step 3: Configure JSON Parser Task to parse Response
  1. Drag and drop the ZS JSON Parser Task from the SSIS toolbox to the design panel.
    Drag-and-Drop JSON Parser Task
  2. We need to configure the JSON Parser Task to parse the response JSON to fetch uploadUri & assetID from the Response. Parse the JSON Properties and set to SSIS Variables as like below sample screenshot.
Step 4: Upload the Document
  1. Add another ZS REST API Task from the SSIS toolbox to upload the Excel file.
  2. Configuring Request Settings tab
  3. Set the Request URL to the pre-signed URL obtained in Step 3.
  4. Change the HTTP Method to PUT .
  5. Enable File Upload/Multi-Part and specify the file path.
  6. Set Content-Type: application/vnd.openxmlformats-officedocument.spreadsheetml.sheet
  7. Execute the task to upload the document.
Step 4: Create PDF from the Uploaded File
  1. Add another ZS REST API Task to send a conversion request.
  2. Select URL Connection - Select your existing OAuth Connection Manager.
  3. Configuring Request Settings tab: set the Request Method to POST.
  4. Enter Request URL: https://pdf-services.adobe.io/operation/createpdf
  5. In the Body (Request Data), specify:
{"assetID": "{uploaded_asset_id}", "targetFormat": "pdf"}
  1. Configure Request Headers: x-api-key:{{User:varClientID}}
  2. Configure Response Tab: Configure Response Headers Mappings to save the location header to the SSIS variable.
  3. Execute the task and store the response, which includes a job ID.
Step 5: Check Status of Conversion
  1. Add another ZS REST API Task to check the conversion status.
  2. Configure Request Settings tab
  3. Select URL Connection - Select your existing OAuth Connection Manager
  4. Set the Request Method to GET .
  5. Use the job ID obtained in Step 4 in the request URL.
  6. Configure Request Headers: x-api-key:{{User:varClientID}}
  7. Configure Response Settings tab
    • Response Filter Expression: $.asset.downloadUri
      (This targets a specific property in the JSON to extract the download URL)
    • Select Variable: User::varDownloadURL
      (This stores the direct download URL returned by the API)
  8. Execute the task until the status indicates completion.
Step 6: Download the PDF
  1. Add a final ZS REST API Task to download the converted PDF.
  2. Configure Request Settings tab: Use the URL from the previous step and set the Request Method to GET.
  3. Configure Response Settings tab
    • Response content type: None
    • Save Mode: Save to File
    • Select Treat response as binary checkbox
    • Enter File Path: User::varPDFFileName
      (This stores the file returned by the API physically to the folder path)
  4. Save the response to a file location.
By following these steps, you can successfully convert an Excel sheet into a PDF using Adobe APIs in SSIS. This workflow ensures automation and seamless integration within your ETL processes.
