Problem Statement
We observed a frustrating issue where an SSIS package using the ZappySys Salesforce connector would run perfectly when executed from Visual Studio (developer environment) or via the SSIS Catalog (SSISDB), but would fail when scheduled via a SQL Server Agent Job.
The error that appeared when run under SQL Agent typically looked like this:
System.Net.WebException: The operation has timed out
at System.Web.Services.Protocols.WebClientProtocol.GetWebResponse(WebRequest request)
at ZappySys.Crm.SdfcPartnerApi.SforceService.query(String queryString)
Interestingly, in Visual Studio or when run manually, the Test Connection always succeeded, and one of the interfaces even worked in VS, whereas others failed under the Agent.
Investigation & What We Tried
We systematically went through multiple common causes:
Package Protection Level / Sensitive Data Handling
Tried
DoNotSaveSensitiveand parameterizing credentials (username, password + security token) -
Tried
EncryptSensitiveWithPassword/EncryptSensitiveWithUserKeyvariants -
Verified that the parameters were being properly passed at runtime
Job / Agent Differences
Created new SQL Agent Jobs (to rule out misconfigurations)
Linked the jobs to SSISDB environments and mapped parameters
Ensured variables in SSIS environments were properly set
Connection Context / Runtime Account
Checked which account the SQL Agent service was running under
Verified that account’s network/firewall access to Salesforce endpoints
Compared that to permissions accessible under the interactive user account
Everything seemed correct — packages and connections worked in VS or SSISDB, parameter values were correct — but under the Agent, the connection would either timeout or not pick up the credentials correctly.
