When working with APIs that use OAuth 2.0 authentication, one common challenge is handling expired access tokens and refreshing them automatically using a refresh token.
In this article, we will walk through how to correctly configure token refresh logic in SSIS using ZappySys components.
Most APIs issue:
- Access Token (short-lived)
- Refresh Token (long-lived)
When the access token expires, you must call the token endpoint again using the refresh token to obtain a new access token.
If this step is not configured correctly, you may encounter:
- 401 Unauthorized errors
- Token refresh failures
- Scheduled jobs breaking after some time
Before you begin, ensure:
- OAuth authentication is already working
- You have
client_id,client_secret, andrefresh_token - Token endpoint URL is available
Step 1: Configure Token Refresh API Call
Use ZappySys API Source / REST API Task / OAuth Connection Manager to call the token endpoint.
Example
POST https://api.example.com/oauth/token
Step 2: Setup Request Body
Configure the request body as:
grant_type=refresh_token
&refresh_token={EncodedRefreshToken}
&client_id={CLIENT_ID}
Step 3: Encode Refresh Token using Placeholder Function
Refresh tokens often contain special characters which must be URL encoded.
Use ZappySys Placeholder function:
{FUN_URLENC(@[User::RefreshToken])}
This ensures:
- Proper encoding of special characters
- Prevents invalid request errors
- Improves compatibility with strict APIs
Step 4: Configure Authentication
Some APIs require client credentials in the Authorization header instead of request body.
Use Basic Authentication
Authorization: Basic BASE64(client_id:client_secret)
This is a critical step.
Incorrect configuration here may result in:
- Unauthorized (401) response
Step 5: Add Required Headers
Content-Type: application/x-www-form-urlencoded
Authorization: Basic <encoded_value>
Step 6: Parse Response and Store Tokens
A successful response typically contains:
“access_token”: “new_access_token”,
“refresh_token”: “new_refresh_token”,
“expires_in”: 1800
In ZappySys:
- Go to Response tab
- Extract values using JSON Path:
$.access_token
$.refresh_token
- Store values in SSIS variables
Step 7: Handle Changing Refresh Token
Some APIs rotate refresh tokens on every request.
This means:
- A new refresh token is returned each time
- Old refresh token becomes invalid
You must always:
- Update stored refresh token
- Use latest value for next request
For detailed implementation, refer to:
Step 8: Testing Token Refresh
To test without waiting for expiration:
- Use token revoke endpoint (if available)
Example:
POST /oauth/revoke
token={ACCESS_TOKEN}
This forces token expiration and helps validate refresh logic.
Common Issues and Fixes
Issue: Unauthorized error during refresh
- Check if
client_secretshould be in header instead of body
Issue: Token refresh works once but fails later
- Ensure refresh token is updated dynamically
Issue: Invalid request error
- Use
FUN_URLENCfor encoding refresh token
Issue: Works in Postman but fails in SSIS
- Match headers and body exactly
By correctly configuring:
- Request body
- Authentication method
- Token parsing and storage
You can fully automate OAuth token refresh in SSIS using ZappySys.
This ensures your packages run reliably without manual token updates.
If you still face issues:
- Validate API behavior in Postman
- Double-check header vs body requirements
- Share logs/screenshots with ZappySys support team:
* Live Chat: Open the chat widget (bottom right of this page)
* Email: support@zappysys.com
* Support Center: Support | ZappySys
