Will zappysys support formatting change.
It seems this change will not impact our ZappySys components. We use SOAP/JSON REST API, which relies on the ISO date format, so it is unaffected by localized formatting. However, if you read any field that sends data in a localized format, it will follow the new format.
That said, it’s always a good practice to set up a new Salesforce sandbox environment with the localized format and test it with our software if you have any concerns.
Example of ISO format returned by the API: 2015-09-04T04:57:36.000Z
Thanks for your reply. we didn’t get chance to test in salesforce sandbox, once tested will reply back.
You’re welcome! No problem—take your time testing in the Salesforce sandbox. Feel free to reach out if you have any questions or need assistance. ![]()
