In this post, we will learn how to read AWS REST API data in ODBC apps like Power BI, Informatica, Excel, and MS Access without coding. This post shows how to use the AWS command line and capture its output directly for reading data into ODBC Apps. If you prefer to take a more low-level approach without installing the AWS command line, then review this blog post.
Requirements
- Download and Install AWS Command Line for Windows (Official Link found here under Windows section)
- Download and Install ODBC PowerPack
Create a new ODBC DSN for AWS API
To gain access for yourself or other users, go to the User DSN or System DSN. Go to the System tab for SQL Server Integration and add a new System DSN. Click the “Add” button.
From the driver list, select ZappySys JSON Driverx and press Finish.
Configure ODBC DSN for AWS Command Line / REST API
- Search for “ODBC” in the start menu and open it.
- Create a new DSN using ZappySys JSON Driver
- Configure JSON API like below
- Run Query to preview data (Example query like below)
SELECT * FROM "$"
WITH(
Src='cmd:>aws ssm describe-available-patches --no-verify-ssl'
,"Filter"='$.Patches[*]'
Loading AWS API Data into Power BI or other Apps
To load data inside Power BI review steps here
Example: Reading EC2 Instances in ODBC Apps
SELECT * FROM $
WITH(
Src='cmd:>aws ec2 describe-instances --no-verify-ssl'
,"Filter"='$.Reservations[*].Instances[*]'
Example: Reading EC2 Patches
SELECT * FROM "$"
WITH(
Download the ZappySys JSON Driver and seamlessly connect AWS REST API data to your favourite ODBC apps like Power BI, Excel, and MS Access without writing any code. Whether you choose the AWS command line approach or prefer a more low-level method, as discussed in the referenced blog post, this tutorial will equip you with the tools and techniques to simplify data access and streamline your workflows.
If you encounter any issues or need further assistance, our support team is available via chat on our website.
