This tutorial explains how to connect Zuora, a subscription management platform, to ODBC-compliant applications such as Power BI, Excel, or SQL Server using the ZappySys ODBC JSON Driver. With this setup, you can query Zuora’s REST API directly and use the data in your reporting or analytics tools.
- A Zuora account.
Step 1: Obtain your Zuora API credentials
Visit Zuora Login and sign in with your account credentials.
Navigate to Settings by clicking your profile icon in the top right, then go to Administration, then go to Manage User Roles and click Add New Role.
Specify a name for the new role, such as API Write Role.
Select the API Write Access checkbox and click Save.
Go back to the Administration Settings page, select Manage Users, and click Add Single User.
Enter your first name, last name, work email, and login name. Ensure that the login name is descriptive and relevant, such as
APIWriteAccess@yourcompany.com -
Create an OAuth client for the account and capture the client ID and client secret. These credentials are needed to obtain tokens before making API calls or using the library.
Step 2: Create a new ODBC DSN using ZappySys JSON Driver
Search for ODBC in the Windows Start menu and open the ODBC Data Source Administrator.
In the User DSN or System DSN tab, click Add to create a new data source.
In the ODBC Data Source Setup window, select the ZappySys JSON Driver and click Continue.
Step 3: Configure ODBC connection for Zuora API calls
Use the following API URL to create a product:
https://rest.test.zuora.com/v1/object/product
You can refer to the Zuora API documentation for more details. -
In the Connection Type field, select OAUTH connection and click Configure.
Set OAuth version to OAuth2.
In OAuth Grant Type, choose Client Credentials Grant. For more details, refer to this article on OAuth 2.0 Client Credentials Grant.
Enter the client ID and client secret you obtained earlier.
Set the Token URL to:
https://rest.test.zuora.com/oauth/token -
Click OK to save the configuration.
Set the HTTP Request Method to POST.
In the request body, use the following example from the API documentation:
{ "Name": "SmartLearn Tablet", "EffectiveStartDate": "2024-01-01", "EffectiveEndDate": "2034-01-01" } -
Set Content-Type to JSON (application/json).
Click Test Connection to verify that the configuration is correct.
Proceed to the Preview Tab to check the response from the API.
By setting up an ODBC DSN with the JSON driver, you can connect Zuora’s REST API directly to tools like Power BI, Excel, or SQL Server. This enables you to query subscription data, automate reporting, and include Zuora information in your broader data workflows.
Visit our official page to start building smarter, faster, and more scalable solutions with ZappySys.
