NEW: All Drivers - Add new property TruncationErrorMode (Options Truncate (Default), Ignore, ThrowError) if string length is more than Metadata Length for String DataType - Default (Truncate) only works when META is supplied in WITH
NEW: All Drivers - Allow to set ConvErrorHandlingMode=Ignore without User defined Metadata / META attribute in WITH clause
NEW: All Drivers - Make ConvErrorHandlingMode=Ignore option faster
NEW: Data Gateway - All Drivers - Report DT_DBDATE in API Driver as date type in SQL Server
Bug fixes
FIX: All Drivers - Import Table / Link Table both fails in MS access when you use v1.9 (Older version works fine)
FIX: API Driver - @OverrideMode in META doesnt work as expected when Name / Label different - You may get error Index was outside the bounds of the array
FIX: JDBC Bridge Driver - Add support for TIME datatype (Right now throws error in LinkedServer - Error converting data type DBTYPE_DBTIMESTAMP to datetime)
FIX: JDBC Bridge Driver - Infor Datalake - You may get Table(s) not found or you do not have permissions: [default.some_table_name].
