OAuth Connection Error - Wrong password, or other cryptographic error - Bad Data
When using an OAuth connection with a refresh token/token cache file in ZappySys SSIS PowerPack or ZappySys ODBC PowerPack, you may encounter the following error at design time or runtime:
Test Failed: Wrong password, or other cryptographic error.
Bad Data.
Cause
The token cache file is encrypted using a combination of Client ID and Client Secret.
If either value changes, the file cannot be decrypted, resulting in a cryptographic error. Common scenarios:
  • Client ID does not match the one used when the token file was created
  • Client Secret was regenerated or modified after the token file was created
  • Token file was copied from another environment with different OAuth settings
  • Make sure both Client ID and Client Secret exactly match the values used when the token cache file was originally created.
  • Do not regenerate or rotate the Client Secret unless you plan to re-authenticate.
  • If the original Client ID or Client Secret is no longer available:
    • Delete the existing token cache file.
    • Re-run authentication to generate a new token file with the updated credentials.
If the issue persists, please contact our support team:
