When connecting to MongoDB using ZappySys MongoDB Connector, you may encounter the following error:
Test Failed: Unable to authenticate using the SASL protocol mechanism SCRAM-SHA-1. Command saslStart failed: Received authentication for mechanism SCRAM-SHA-1, which is not enabled.
This error typically indicates a mismatch between the authentication mechanism configured in MongoDB and what the connector is using.
Cause
- MongoDB server requires SCRAM-SHA-256, but connector defaults to SCRAM-SHA-1.
- Missing
authSourceparameter in the connection string. - Password not being passed correctly due to SSIS ProtectionLevel settings.
- Might be using an older version of SSIS PowerPack.
Solution 1 – Specify authSource Parameter (User-Confirmed Fix)
The issue was resolved by adding the following advanced parameter in the connection string:
authSource=admin
This ensures the connector authenticates against the correct database where user credentials are stored.
Solution 2 – Ensure Correct Authentication Mechanism
Add the following option to the connector:
authMechanism=SCRAM-SHA-256
Make sure this matches the mechanism configured on your MongoDB server.
Solution 3 – Verify Password and Variables
- Ensure the password field is not blank.
- If using SSIS variables or parameters, confirm the values are being passed correctly.
- Change ProtectionLevel in SSIS package to
EncryptSensitiveWithUserKeyor similar to avoid empty credentials at runtime.
You can find the Troubleshooting Guide here for your reference.
Solution 4 – Update ZappySys PowerPack
Older builds may have limited support for advanced MongoDB authentication.
- Check your SSIS PowerPack version
- Download the latest version of SSIS PowerPack or a newer release:
Download Latest Build - Review SSIS PowerPack Release Notes for MongoDB enhancements.
Summary
By specifying authSource=admin, confirming the authentication mechanism authMechanism=SCRAM-SHA-256, verifying credentials, and updating to the latest build, you can resolve most SCRAM-SHA-related MongoDB connection issues in ZappySys.If you continue to face issues or have specific questions, please reach out to our support team via live chat.
