ZappySys JDBC-ODBC Bridge Driver works best with Java 8 runtime. If you have multiple Java runtimes installed on your machine, that can become a problem. Problems start to arise if one of JREs version is higher than Java 8 and is set as default Java runtime (JAVA_HOME system environment variable). In that case you may start getting errors when using ODBC data source based on ODBC-JDBC Bridge Driver.
The solution to this problem is to simply configure Java path in JDBC Bridge settings file and set it to where Java 8 runtime is located:
- Follow this article on how to set JDBC Bridge options and create
JdbcBridge.propertiesfile in the folder where ZappySys ODBC PowerPack is installed, e.g.C:\Program Files (x86)\ZappySys\ZappySys ODBC PowerPack - Add a line with property
java.pathpointing to JRE 8binfolder, e.g.:
java.path=c:\Program Files\Amazon Corretto\jdk1.8.0_382\bin
If you don’t have Java 8 runtime installed, you can download it from these sites:
