How to read Infor Data Lake in SSIS (use Compass JDBC Driver for Data Fabric)
Many Vendors (like Infor Data Lake) offer only JDBC drivers and do not offer ODBC drivers. If you are thinking about how to use Java Driver in Non-Java apps (e.g. Excel, SSIS, Power BI) to perform some data integration then no worries.
We have a Product called JDBC Bridge Driver which can convert JDBC Driver calls to ODBC calls so any non-java app can use JDBC drivers without issue Check this article for detailed steps.
For example: You can load data from Infor Data Lake using their JDBC Driver two different ways (See below)
Method 1
Connect via SSIS–>ODBC Soure–>ZappySys JDBC Bridge–> Infor JDBC → Infor Data Lake
For this method: You need ODBC PowerPack installed on both sides (client / server) - Install on the Workstation (to design/ debug SSIS Packages) and Install on the SSIS Server after deployment.
Method 2
Connect via SSIS–>OLEDB Source → SQL Server -->Linked Server–> ZappySys Data Gateway → ZappySys JDBC Bridge → Infor JDBC → Infor Data Lake
For this method: You need ODBC PowerPack installed on the Server only.
After this, you can consume data in SSIS by writing a query like below in OLEDB source
SELECT * FROM OPENQUERY(LS_INFOR, 'select col1 from some_infor_table')
