In this article, we’ll walk you through the process of connecting to SharePoint Online Excel using the ZappySys connector within SSIS. This integration allows you to seamlessly retrieve and manage your SharePoint data, making it easier to incorporate into your workflows and applications. By following these steps, you’ll be able to efficiently extract and process data with our SharePoint connector, which is part of the ZappySys SSIS PowerPack.
- Download and install the ZappySys SSIS PowerPack
- Microsoft account
Step 1: Register an Application in Microsoft Azure
To authenticate and access SharePoint Online, you need to register an application in Azure Active Directory.
Log in to the Azure Portal and go to Azure Active Directory.
In the left menu, click on App registrations.
Click New registration and enter a name for your application.
Choose the supported account type and set the Redirect URI to:
https://login.microsoftonline.com/common/oauth2/nativeclient -
Once the app is created, copy the following credentials from the app configuration: Client ID, Tenant ID, and Secret ID
Step 2: Connect to SharePoint in SSIS
Drag and drop an API Source component inside the Data Flow.
Create a new connection and select the SharePoint Online connector. Click Next to proceed.
Fill in the required fields with your credentials: Client ID, Client Secret, and Authorization and Token URLs. Use the following URLs based on your Tenant ID:
- Authorization URL:
https://login.microsoftonline.com/{TenantID}/oauth2/v2.0/authorize - Authorization URL (Without TenantID):
https://login.microsoftonline.com/common/oauth2/v2.0/authorize - Token URL:
https://login.microsoftonline.com/{TenantID}/oauth2/v2.0/token - Token URL (Without TenantID):
https://login.microsoftonline.com/common/oauth2/v2.0/token
Generate the token and save the configuration.
Select a table/endpoint, Read Excel Worksheet, fill the required fields and preview the data.
- Store credentials securely for future use.
- Ensure the permissions assigned to the registered application allow access to SharePoint data.
Watch this tutorial for a step-by-step walkthrough:
By following these steps, you can easily integrate SharePoint Online Excel into SSIS using the ZappySys connector. This setup streamlines data retrieval and enhances automation, improving your workflow efficiency.
To get started, download and install the ZappySys SSIS PowerPack. If you encounter any challenges, review your configuration settings and error logs. For additional assistance, contact ZappySys Support.
For more advanced SSIS file operations, explore the ZappySys SSIS PowerPack.
