How to get SharePoint Site ID for API calls using the Browser
If you are using ZappySys SharePoint Online Connector, you may encounter the following challenge when selecting the Site ID Parameter in the connection UI due to permission or UI limitations.
  • Your Microsoft Graph permissions are limited, and you cannot list all sites (Throws access denied error)
  • Your Site ID is not listed in the SharePoint Connector UI (Due to the maximum limit for items in the drop-down)
Regardless of the above issue, you can still manually build the full siteId by using the classic SharePoint REST API directly in your browser.
:compass: Step 1 — Open the Site in Your Browser
Go to your SharePoint site, for example:
https://YOUR-COMPANY.sharepoint.com/sites/MY-SITE-NAME
Keep this tab open — you’ll use it as the base URL for the next step.
:camera_with_flash: Example:
:puzzle_piece: Step 2 — Find the Site Collection ID
In the same browser window, navigate to this URL (append _api/site/id):
https://YOUR-COMPANY.sharepoint.com/sites/MY-SITE-NAME/_api/site/id
You’ll see an XML or JSON response showing the Site Collection ID GUID:
<?xml version="1.0" encoding="utf-8"?>
<d:Id xmlns:d="http://schemas.microsoft.com/ado/2007/08/dataservices"
	xmlns:m="http://schemas.microsoft.com/ado/2007/08/dataservices/metadata"
	xmlns:georss="http://www.georss.org/georss"
	xmlns:gml="http://www.opengis.net/gml"
	m:type="Edm.Guid">37bb36ba-49b5-4f39-a627-d0xxxxxxxx</d:Id>
Copy that value — this is your Site Collection ID. (example: 37bb36ba-49b5-4f39-a627-d0xxxxxxxx )
:puzzle_piece: Step 3 — Find the Web ID
Now open this URL (append _api/web/id):
https://YOUR-COMPANY.sharepoint.com/sites/MY-SITE-NAME/_api/web/id
The response will show the Web ID GUID:
<?xml version="1.0" encoding="utf-8"?><d:Id xmlns:d="http://schemas.microsoft.com/ado/2007/08/dataservices" xmlns:m="http://schemas.microsoft.com/ado/2007/08/dataservices/metadata" xmlns:georss="http://www.georss.org/georss" xmlns:gml="http://www.opengis.net/gml" m:type="Edm.Guid">fbaac4df-73da-469a-86fa-b3xxxxxxxx</d:Id>
Copy that value — this is your Web ID.
:abacus: Step 4 — Build the Full siteId
Combine the three parts in this exact order:
{hostname},{site-collection-id},{web-id}
:white_check_mark: Example
your-company.sharepoint.com,37bb36ba-49b5-4f39-a627-d0xxxxxxx,fbaac4df-73da-469a-86fa-b3xxxxxxx
You can now use this value in Microsoft Graph API calls such as:
GET https://graph.microsoft.com/v1.0/sites/{siteId}/lists
Your URL in API call may look like this
https://graph.microsoft.com/v1.0/sites/your-company.sharepoint.com,37bb36ba-49b5-4f39-a627-d0xxxxxxx,fbaac4df-73da-469a-86fa-b3xxxxxxx/lists
:receipt: Summary
Value Example Source
Hostname your-company.sharepoint.com From site URL
Site Collection ID 37bb36ba-49b5-4f39-a627-d0xxxxxxx _api/site/id
Web ID fbaac4df-73da-469a-86fa-b3xxxxxxx _api/web/id
Full Site ID your-company.sharepoint.com,37bb36ba-49b5-4f39-a627-d0xxxxxxx,fbaac4df-73da-469a-86fa-b3xxxxxxx Combine all
Now you can use this value on your SharePoint API Connector UI like below
