When you click Generate Token button, you may get an error like the one below.
Salesforce OAuth Generate Token Error – Missing Required Code Challenge
Here is how to fix it.
For Salesforce Connection UI: Go to Advanced Tab => Check Enable PKCE Code Verifier option
–OR–
For OAuth Connection UI: Go to OAuth2 Grant Options Tab => Check Enable Code Verifier Option
Enable PKCE code verifier option – OAuth Connection for Salesforce.
