How to fix JBR error: java.sql.SQLException: Data Lake is not available - Unable to verify trust for server certificate chain [CN=****-ionapi.inforcloudsuite.com...]
PROBLEM
If you are using our JDBC Bridge driver to call Infor Data Lake in non-Java Apps (e.g. ODBC App like Power BI, Excel, etc) then sometimes you might get the below error if Java Certificate Store doesn’t have certificate trusted). You might get the below error
at com.infor.idl.jdbc.Driver.connect(Driver.java:422)
at DbConnection.Init(DbConnection.java:45)
at ClientHandler.openConnection(ClientHandler.java:245)
Caused by: com.infor.idl.shaded.javax.ws.rs.ProcessingException:
javax.net.ssl.SSLHandshakeException:
Unable to verify trust for server certificate chain [CN=mingle-ionapi.inforcloudsuite.com, CN=pa-trusted-ca.noble.loc, CN=noble-SUBCA-CA, DC=noble, DC=loc, CN=ROOTCA-CA, CN=ROOTCA-CA]
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559)
SOLUTION
There are several reasons why you might be getting this error, so here are a few possible solutions:
Solution-1: Disable the SSL Decryption option in firewall software see helps
Many times company firewall software has an SSL description option turned on. Ask your network admin to check this to see it can be the cause of the Certificate Validation failure in Infor JDBC. You can try to exclude *.inforcloudsuite.com from decryption and see if it helps.
See below example link of 3rd party Firewall Software (from PALO-networks ) - Settings to exclude certain domains from SSL Decryption. You may or may not have such an option in your firewall but if you do you can adjust it to see if it helps.
Example of PALO firewall >> (Device > Certificate Management > SSL Decryption Exclusion)
Solution-2: Import the certificate in JAVA Certificate Store so its always trusted
(https://www.baeldung.com/jvm-certificate-store-errors)
Example of calling keytool.exe
keytool -import -alias ss-badssl.com -keystore $JAVA_HOME/lib/security/cacerts -file ss-badssl.pem
Solution-3: Contact Infor support
If the above solutions did not help or are not relevant, it’s recommended to contact Infor support. Incorrect Infor account configuration can sometimes cause connectivity issues. Several ZappySys clients have successfully resolved similar problems with Infor’s support help.
