How to enable JDBC Bridge Driver Logging
If you like to capture details about ZappySys JDBC Bridge Driver then you can enable log using below way
For v1.8.2 and older
Create a new file JdbcBridge.properties with the following content (change path as per your need. Keep slash like below in the path else Java will complain)
app.logfile=c:/temp/JdbcBridge_log.txt
and save to the following 3 locations (you can copy same file in these 3 directories)
For 64-Bit driver
Copy to C:\Program Files (x86)\ZappySys\ZappySys ODBC PowerPack\JdbcBridgeDriverX64
For 32-Bit driver
For Data Gateway
Copy to C:\Program Files (x86)\ZappySys\ZappySys ODBC PowerPack\ZappySys.TdsServer.WindowsService
For v1.8.3 and higher
In new version you can create JdbcBridge.properties only at one location below no need to copy in 3 folder like above.
Copy to below path
