Sometimes, specific use cases or system compatibility requirements necessitate using an earlier version of the ZappySys SSIS PowerPack. For customers with an active subscription or valid support contract, ZappySys provides a straightforward process for downloading previous versions from its website. This article explains how to locate and download earlier versions of the SSIS PowerPack.
Why Use an Earlier Version?
You might need an earlier version of the SSIS PowerPack for several reasons:
- Compatibility: Ensuring compatibility with legacy systems or applications.
- Stability: Using a version proven stable in your production environment.
- Support Requirements: Resolving specific issues or working within constraints imposed by dependent tools.
Steps to Download Earlier Versions
Step 1: Log in to the ZappySys Customer Download Area
- Visit the ZappySys Customer Download Area.
- Use your Order Number, License Key, or Machine Code (find your Machine Code here), and click Submit to access the installer.
Step 2: Navigate to Previous Versions
Scroll to the bottom of the page and click Download Older Build.
A list of all available versions of the SSIS PowerPack, including release dates and changelogs, will be displayed.
- Review the changelog to confirm the version meets your requirements.
Click on the desired version to begin downloading.
Step 3: Install the Earlier Version
- Uninstall the Current Version:
- Open Control Panel > Programs and Features and uninstall the existing ZappySys SSIS PowerPack.
- Run the Installer:
- Open the installer for the earlier version you downloaded and follow the on-screen instructions.
Important Notes
- Active Support Contract: Access to earlier versions requires an active subscription or support license.
- Backup Your Configuration: Before uninstalling the current version, back up your existing packages to prevent the loss of your settings.
- Testing Recommendation: Use a test environment to verify the earlier version before deploying it in production.
For users with active support contracts, accessing earlier versions of the ZappySys SSIS PowerPack is straightforward. By following this guide, you can ensure compatibility with legacy systems or resolve specific issues while leveraging ZappySys tools. If you need assistance, feel free to contact the ZappySys Support Team.
