Sometimes, specific use cases or system compatibility requirements necessitate using an earlier version of the ZappySys ODBC PowerPack. For customers with an active subscription or valid support contract, ZappySys provides a straightforward process for downloading previous versions from their website. This article explains how to locate and download earlier versions of the ODBC PowerPack.
Why Use an Earlier Version?
You might need an earlier version of the ODBC PowerPack for several reasons:
- Compatibility: Ensuring compatibility with legacy systems or applications.
- Stability: Using a version proven stable in your production environment.
- Support Requirements: Resolving specific issues or working within constraints imposed by dependent tools.
Steps to Download Earlier Versions
Step 1: Log in to the ZappySys Customer Download Area
Visit the ZappySys Customer Download Area.
Use your Order # and your License key or the Machine code you can find here; then press Submit to access the paid installer
Step 2: Navigate to Previous Versions
Navigate to the bottom of the page and press Download older build
It will show the lists of all available versions of the ODBC PowerPack, including their release dates and changelogs.
Select the version you want to download
Step 3: Install the Earlier Version
- To avoid conflicts, uninstall the currently installed version of the ODBC PowerPack before installing the earlier version: Open Control Panel > Programs and Features and uninstall ZappySys ODBC PowerPack.
- Run the installer for the earlier version you downloaded and follow the on-screen instructions.
- Configure your ODBC connections as needed.
Important Notes
- Active Support Contract: Access to earlier versions typically requires an active support license
- Backup Your Configuration: Before uninstalling or switching versions, backup your existing configuration to avoid losing custom settings. This article can help with this.
For a detailed walkthrough, check out this video tutorial:
For users with active support contracts, accessing earlier versions of the ZappySys ODBC PowerPack is straightforward. By following the steps outlined in this guide, you can ensure compatibility with legacy systems or resolve specific issues while leveraging the powerful features of ZappySys tools. For further assistance, contact the ZappySys Support Team.
