How to connect to Outlook API with Ruby using ODBC
In this article, we will show how to connect with the Outlook API with Ruby using the ODBC interface.
Connecting Ruby to Outlook via ODBC allows you to seamlessly interact with your emails, contacts, calendar events, and other Outlook data programmatically.
By leveraging the ruby-odbc gem, you can automate email processing, extract relevant data, and integrate Outlook with other applications. This guide will walk you through the installation, configuration, and troubleshooting process to establish a reliable connection between Ruby and Outlook using ODBC.
Step 1: Install Ruby and the ruby-odbc Gem
Some versions of Ruby may not be fully compatible with the ruby-odbc gem. To ensure proper functionality, using Ruby 3.1.x is recommended, as newer versions may introduce compatibility issues.
  1. Download the Ruby Installer.
  2. Install Ruby and DevKit.
  3. Open Command Prompt as an administrator.
  4. Verify the version you use with this command ruby -v.
  5. Install the ruby-odbc gem with the following command: gem install ruby-odbc.
  6. Verify the gem installed with this command: gem list ruby-odbc.
NOTE: If you encounter installation issues, you may need administrative permissions.
Step 2: Create an Application in Microsoft Azure
  1. Log into the Azure Portal and navigate to Azure Active Directory.
  2. Click on App registrations in the left menu.
  3. Select New registration and provide a name for your application.
  4. Choose the supported account type and specify the Redirect URI as https://login.microsoftonline.com/common/oauth2/nativeclient.
  5. Copy the Application (client) ID, Tenant ID, and Secret ID from your App configuration:
Step 3: Create an ODBC data source based on API Driver
  3. From the driver list, select ZappySys API Driver, then choose Outlook Mail (Office 365) from the connector list and press Continue.
Step 4: Configure Outlook Mail (Office 365) Connector
  1. Fill in the connector fields with the Client ID, Client Secret, the necessary scopes, and the appropriate Authorization and Token URLs. Then generate the token:
    • Authorization URL: https://login.microsoftonline.com/daed1250-xxxx-xxxx-xxxx-ef0a982d3d1e/oauth2/v2.0/authorize
    • Authorization URL (Without Tenant ID): https://login.microsoftonline.com/common/oauth2/v2.0/authorize
    • Token URL: https://login.microsoftonline.com/daed1250-xxxx-xxxx-xxxx-ef0a982d3d1e/oauth2/v2.0/token
    • Token URL (Without Tenant ID): https://login.microsoftonline.com/common/oauth2/v2.0/token
  2. Go to the Preview Tab, select a table, and click Preview Data to view the results. Click OK to save the configuration.
Step 5: Access Outlook API with Ruby via ODBC data source
Once the DSN is set up, you can use ruby-odbc to establish the connection and run queries. Create a Ruby file, e.g., OutlookRuby.rb :
require 'odbc'
# DSN name configured in ODBC
dsn = "API Driver - Outlook Mail"  # Replace with the correct name
begin
  # Connect to the database using DSN
  db = ODBC.connect(dsn)
  # Verify connection
  puts "✅ Successfully connected to ODBC"
  # Execute a test query
  query = "SELECT * FROM MyMessages"  # Adjust according to your database
  stmt = db.run(query)
  # Check if there is data
  rows = stmt.fetch_all
  if rows.empty?
    puts "⚠️ No data found in the database."
  else
    # Display results
    rows.each do |row|
      puts row.inspect
    end
  end
  # Close connection
  stmt.close
  db.disconnect
rescue ODBC::Error => e
  puts "❌ Connection error: #{e.message}"
end
When you run the code, it will call the Outlook API via ODBC and retrieve data about your campaign lists.
Common errors and solutions
:cross_mark: Error: cannot load such file -- dbi (LoadError)
Cause
You are trying to use the dbi gem, but it is not installed.
In the command line, run these commands to install the ODBC connectors.
gem install dbi
gem install dbd-odbc
:cross_mark: Error: Failed to build gem native extension.
Cause
A compiler or necessary libraries are missing when compiling the gem.
In the command line, install MSYS2 and ensure gcc and make are available.
:cross_mark: Error: Data source name not found, and no default driver specified.
Cause
The DSN is not configured, or the driver is not installed.
  • Verify the configuration in odbcad32.exe
  • Ensure the DSN name in the code exactly matches the one configured in ODBC.
:cross_mark: Error: Issues with Ruby Version
Cause
Some Ruby versions may not be compatible with the ruby-odbc gem, especially if they are too new or old.
  • Check your Ruby version with:
    ruby -v
  • If your version is 3.2.x and you experience issues, try using an earlier version of Ruby (e.g., 2.7.x) or use RVM to switch versions:
    rvm install 2.7.8
    rvm use 2.7.8
Integrating Ruby with Outlook through ODBC provides a powerful way to efficiently manage emails, contacts, and calendar events. Following this guide, you learned how to set up the connection, troubleshoot potential issues, and enhance automation workflows.
To put this into reality, download and install the ZappySys ODBC PowerPack to enable ODBC connectivity and get started.
If you experience any challenges, review the error logs and verify your DSN configuration. If you still cannot figure out the solution yourself, you can always contact ZappySys Support.
