How to connect To OData in ODBC
OData (Open Data Protocol) is a standardized protocol for creating and consuming data APIs. It allows the creation and consumption of queryable and interoperable RESTful APIs in a simple and standard way. OData helps you focus on your business logic while building RESTful APIs without worrying about the various approaches to define request and response headers, status codes, HTTP methods, URL conventions, media types, payload formats, query options, etc. The ZappySys OData Connector for ODBC is a powerful tool that integrates any REST API that supports the OData standard, enabling you to view and read data from tables effortlessly.
Create a New Driver
  3. From the driver list, select ZappySys API Driver, then select OData in the connector list and press Continue.
OData Connector Configuration
  1. Select Authentication Type, e.g. Token Authentication. Then select API Base URL (in most cases, the default one is the right one). More info is available in the Authentication section.
Save the authentication details so you do not have to search for them in your account every time.
Following these steps, you can seamlessly connect to OData within the ODBC API Driver, leveraging the ZappySys tool for efficient data retrieval and integration. For assistance or inquiries, contact our support team via chat on our website.
For more detailed information, refer to our ZappySys OData connector.
