How to connect to MailChimp with Ruby using ODBC
In this article, we will show how to connect to the Mailchimp API with Ruby using the ODBC interface.
Connecting Ruby to Mailchimp via ODBC allows seamless access to your email marketing data, enabling you to automate subscriber management, retrieve campaign statistics, and integrate Mailchimp with other applications.
By leveraging the ruby-odbc gem, you can efficiently interact with Mailchimp lists, campaigns, and reports, streamlining your marketing automation. This guide will walk you through the installation, configuration, and troubleshooting process to establish a reliable connection between Ruby and Mailchimp using ODBC.
Step 1: Installing Ruby and the ruby-odbc Gem
Some versions of Ruby may not be fully compatible with the ruby-odbc gem. To ensure proper functionality, using Ruby 3.1.x is recommended, as newer versions may introduce compatibility issues.
  1. Download the Ruby Installer.
  2. Install Ruby and DevKit.
  3. Open Command Prompt as an administrator.
  4. Verify the version you use with this command ruby -v.
  5. Install the ruby-odbc gem with the following command: gem install ruby-odbc.
  6. Verify the gem installed with this command: gem list ruby-odbc.
NOTE: If you encounter installation issues, you may need administrative permissions.
Step 2: Get Credentials from Mailchimp
Method 1: OAuth Authentication
  1. To connect via OAuth, navigate to the Registered Apps page in your Mailchimp account and click Register An App.
  2. Complete the registration form. For the Redirect URL field, enter https://zappysys.com/oauth2.
  3. Save the provided Client ID and Client Secret for later use.
Method 2: API Key Authentication
  1. To connect via API Key, generate it in your Mailchimp account.
  2. Click Create a Key, name it, and copy the new key for later use. Refer to Mailchimp’s API documentation here.
Step 3: Create a New Driver
  2. For individual or shared access, select User DSN or System DSN. Click Add under the System tab to add a new System DSN.
  3. From the driver list, select ZappySys API Driver, choose Mailchimp from the connector list, and press Continue.
Step 4: Mailchimp Connector Configuration
  1. For OAuth Authentication, select OAuth as the authentication type, then enter your Client ID, Client Secret, Data Center, and Default List-ID. A dropdown menu allows selecting the Default List ID.
    Note: Identify the Data Center (DC) from your Mailchimp URL. For instance, https://us1.admin.mailchimp.com/account/api/manage indicates us1 is the Data Center.
  2. For API Key Authentication, enter the API Key, Data Center, and Default List-ID, then test the connection.
  3. Go to the Preview Tab, select a table, and click Preview Data to view results. Click OK to save your configuration.
Step 5: Connecting Ruby to Mailchimp via ODBC
Once the DSN is set up, you can use ruby-odbc to establish the connection and run queries. Create a Ruby file, e.g., MailchimpRuby.rb :
require 'odbc'
# DSN name configured in ODBC
dsn = "API Driver - Mailchimp"  # Replace with the correct name
begin
  # Connect to the database using DSN
  db = ODBC.connect(dsn)
  # Verify connection
  puts "✅ Successfully connected to ODBC"
  # Execute a test query
  query = "SELECT * FROM Campaigns"  # Adjust according to your database
  stmt = db.run(query)
  # Check if there is data
  rows = stmt.fetch_all
  if rows.empty?
    puts "⚠️ No data found in the database."
  else
    # Display results
    rows.each do |row|
      puts row.inspect
    end
  end
  # Close connection
  stmt.close
  db.disconnect
rescue ODBC::Error => e
  puts "❌ Connection error: #{e.message}"
end
When you run the code, it will call the Mailchimp API via ODBC and retrieve data about your campaign lists.
Common errors and solutions
:cross_mark: Error: cannot load such file -- dbi (LoadError)
Cause
You are trying to use the dbi gem, but it is not installed.
In the command line, run these commands to install the ODBC connectors.
gem install dbi
gem install dbd-odbc
:cross_mark: Error: Failed to build gem native extension.
Cause
A compiler or necessary libraries are missing when compiling the gem.
In the command line, install MSYS2 and ensure gcc and make are available.
:cross_mark: Error: Data source name not found, and no default driver specified.
Cause
The DSN is not configured, or the driver is not installed.
  • Verify the configuration in odbcad32.exe
  • Ensure the DSN name in the code exactly matches the one configured in ODBC.
:cross_mark: Error: Issues with Ruby Version
Cause
Some Ruby versions may not be compatible with the ruby-odbc gem, especially if they are too new or old.
  • Check your Ruby version with:
    ruby -v
  • If your version is 3.2.x and you experience issues, try using an earlier version of Ruby (e.g., 2.7.x) or use RVM to switch versions:
    rvm install 2.7.8
    rvm use 2.7.8
Integrating Ruby with Mailchimp through ODBC provides a powerful way to manage email marketing data, automate workflows, and enhance reporting capabilities. By following this guide, you have learned how to set up the connection, troubleshoot potential issues, and improve data accessibility.
To get started, download and install the ZappySys ODBC PowerPack to enable ODBC connectivity with Mailchimp.
If you experience any challenges, review the error logs and verify your DSN configuration. If you still need assistance, feel free to reach out to ZappySys Support.
Contact Us
