How to connect to JSON file / URL using ODBC Driver
With ZappySys JSON Driver for ODBC, users can seamlessly access and manipulate JSON data from various local sources, facilitating efficient data analysis, reporting, and workflow automation. This tool is compatible with ODBC-supported applications such as SQL Server, Excel, Power BI, and more, enabling comprehensive data processing and visualization. With the ability to handle complex JSON structures, the ZappySys JSON Driver simplifies extracting meaningful insights from JSON data, ensuring accurate and up-to-date information for decision-making.
Create a New Driver
  3. From the driver list, select ZappySys JSON Driver.
JSON Driver Configuration
  1. Use our tool to select any local JSON file. You can use a wildcard in the path to get more than one JSON file with the same format.
Following these steps, you can seamlessly connect to a JSON local file within the ODBC JSON Driver, leveraging the ZappySys tool for efficient data retrieval and integration. For assistance or inquiries, contact our support team via chat on our website.
For more detailed information, refer to our ZappySys JSON Driver.
