This guide will walk you through connecting Microsoft Excel to the Google Drive API using the ZappySys ODBC API Driver, enabling seamless data integration and retrieval. The ZappySys ODBC Google Drive Connector provides a robust solution for integrating Google Drive data into Excel for reporting and analysis.
- Have a Google account: Ensure you have a Google account to access Google Drive data.
Step 1: Create/Select a Project in Google API Console:
Navigate to the Google API Console.
Enable both Sheets API and Drive API by searching for them and clicking ENABLE.
Return to the main screen and click on the OAuth Consent Screen tab. Provide the necessary details and save.
Move to the Credentials tab.
Step 2: Create a New Driver
To gain access for yourself or other users, go to the User DSN or System DSN. Go to the System tab for SQL Server Integration and add a new System DSN. Click the “Add” button.
From the driver list, select ZappySys API Driver, then select Google Drive in the connector list and press Continue.
Step 3: Google Drive Connector Configuration
Fill in the connector fields, including Client ID, Client Secret, and Scopes.
Generate the token and test the connection.
Go to the Preview Tab, select any table, and preview the result. Press OK to save the configuration.
Step 4: Read data in Excel from the DSN
In Excel click Data, then select Get Data, proceed with From Other Sources and choose From ODBC item. This will get data from the ODBC data source we created:
A small window opens, then select the data source you created in previous steps:
You will most likely be asked to authenticate to a newly created DSN. Just select the Windows authentication option together with the Use my current credentials option:
You will be asked to select a table or view to get data. Select one and load the data!
Finally, use data extracted from REST API API in an Excel worksheet:
Save the credentials so you do not have to search for them in your account every time.
The article provides steps to guide users through connecting Excel with Google Drive services using our ODBC API driver. If you encounter any issues or need further assistance, feel free to contact our support team via chat on our website
