This guide will walk you through connecting Microsoft Excel to the Google Calendar API using the ZappySys ODBC API Driver, enabling seamless data integration and retrieval. The ZappySys ODBC Google Calendar Connector provides a robust solution for integrating Google Calendar data into Excel for reporting and analysis.
- Have a Google account: Ensure you have a Google account to access Google Calendar data.
Step 1: Create/Select a Project in Google API Console:
Go to the Google API Console.
Search for Google Calendar API and enable it by clicking ENABLE.
Go to the OAuth Consent Screen tab, provide the necessary details, and save.
Move to the Credentials tab.
Step 2: Create a New Driver
To gain access for yourself or other users, go to the User DSN or System DSN. Go to the System tab for SQL Server Integration and add a new System DSN. Click the “Add” button.
From the driver list, select ZappySys API Driver, then choose Google Calendar from the connector list and press Continue.
Step 3: Google Calendar Connector Configuration
Fill in the connector fields with the Client ID, Client Secret, and the necessary scopes. Then generate the token:
Go to the Preview Tab, select a table, and click Preview Data to view the results. Click OK to save the configuration.
Step 4: Read data in Excel from the DSN
In Excel click Data, then select Get Data, proceed with From Other Sources and choose From ODBC item. This will get data from the ODBC data source we created:
A small window opens, then select the data source you created in previous steps:
You will most likely be asked to authenticate to a newly created DSN. Just select the Windows authentication option together with the Use my current credentials option:
You will be asked to select a table or view to get data. Select one and load the data!
Finally, use data extracted from REST API API in an Excel worksheet:
Save the credentials so you do not have to search for them in your account every time.
The article provides steps to guide users through connecting Excel with Google Calendar services using our ODBC API driver. If you encounter any issues or need further assistance, feel free to contact our support team via chat on our website
