This guide demonstrates how to connect Microsoft Access to the Smartsheet API using the ZappySys ODBC API Driver, ensuring seamless data integration and retrieval. The ZappySys ODBC Smartsheet Connector offers a reliable solution for incorporating Smartsheet data into MS Access for enhanced reporting and analysis.
- Smartsheet Account
1. Create a Token to Access the Smartsheet REST API
Log in to your Smartsheet account.
Navigate to Account > Apps & Integrations > API Access and click Generate Token.
After generating the token, copy it securely for later use (treat this token as sensitive information).
2. Configure the ZappySys ODBC Driver
Open the ODBC Data Source by searching for “ODBC” and launching the ODBC Data Source Administrator.
Go to the User DSN or System DSN tab, depending on your setup. Click Add to create a new data source.
Select ZappySys API Driver, then choose Smartsheet from the connector list. Click Continue.
3. Configure the Smartsheet Connector
Enter the API Token you generated, earn the token field, and enter into the token field. Test that the connecting works correctly.
Go to the Preview Tab, select a table, and Preview tab data. Click OK to save the configuration.
4. Import Data into Microsoft Access
Open Microsoft Access and create a new database.
Go to External Data > New Data Source > From Other Sources and select ODBC Database.
Choose Import the source data into a new table in the current database.
Under Machine Data Source, select the configured data source and click OK.
Select the desired tables and views, then import the data. You can choose multiple tables.
Once imported, your Smartsheet data will appear in the Access database.
5. Use Linked Tables for Real-Time Data Access
Linked tables in MS Access allow real-time data updates without duplication.
Choose Link to Data Source by creating a linked table.
Under Machine Data Source, select your configured data source and click OK.
Select the tables or views you want to link.
Skip the step for selecting a unique key column by clicking OK.
Open the linked table to load and view live data.
- Save Authentication Details: Save your API Token securely to streamline future connections.
- Linked Tables: Use linked tables for real-time data access, but note that performance may be slower than when importing data.
With these steps, you can efficiently connect Microsoft Access to Smartsheet using the ZappySys ODBC API Driver. This integration simplifies data management and enables powerful reporting and analysis. If you need assistance, feel free to contact the ZappySys support team.
