This guide provides a step-by-step walkthrough to connect MS Access to OData using the ZappySys ODBC API Driver for efficient data integration. This connection simplifies managing and analyzing OData data across various applications.
- ODBC PowerPack: Download and install the ZappySys ODBC PowerPack from the Customer Download Area or try the trial version.
Create a New ODBC Driver
Open ODBC Data Source by searching “ODBC” on your system.
To enable access for yourself or other users, go to User DSN or System DSN. Select System DSN for SQL Server Integration and click Add.
From the driver list, choose ZappySys API Driver, select OData from the connector list, and press Continue.
Configure the OData Connector
Set the Authentication Type (e.g., Token Authentication) and specify the API Base URL. For additional details, refer to the Authentication section.
Go to the Preview Tab, select a table, and review the result. Click OK to save your configuration.
Import Data in Microsoft Access
Open MS Access and create a new database.
Navigate to External Data > New Data Source > Other Sources > ODBC Database.
Choose Import the source data into a new table.
Under Machine Data Source, select your newly created data source and click OK.
Select tables and views to import, then load the data.
Using Linked Tables for Live Data (Optional)
Linked tables in Microsoft Access allow real-time access to data, centralized management, and simplified maintenance, which is especially useful for online databases.
In MS Access, open the database where you want to create the linked table.
Go to External Data > New Data Source > ODBC Database and choose Link to Data Source by creating a linked table.
Continue to the Data Source Selection window, then select the desired Machine Data Source. Click OK to confirm.
Choose tables and views to link, then skip the Unique Key selection when prompted. Double-click the linked table to load data.
Save your authentication details for quick access in future sessions.
Using the ZappySys ODBC API Driver, you can seamlessly connect MS Access to OData, enabling efficient data integration and analysis. For additional help, visit our support team on the ZappySys website.
