This article guides you through connecting to the Google Drive API in the ODBC API Driver. This enables seamless integration and management of Google Drive data using the ZappySys ODBC Google Drive Connector.
- Have a Google account: Ensure you have a Google account to access Google Drive data.
Create/Select a Project in Google API Console:
Navigate to the Google API Console.
Enable both Sheets API and Drive API by searching for them and clicking ENABLE.
Return to the main screen and click on the OAuth Consent Screen tab. Provide the necessary details and save.
Move to the Credentials tab.
Create a New Driver
To gain access for yourself or other users, go to the User DSN or System DSN. Go to the System tab for SQL Server Integration and add a new System DSN. Click the “Add” button.
From the driver list, select ZappySys API Driver, then select Google Drive in the connector list and press Continue.
Google Drive Connector Configuration
Fill in the connector fields, including Client ID, Client Secret, and Scopes.
Generate the token and test the connection.
Go to the Preview Tab, select any table, and preview the result. Press OK to save the configuration.
Save the credentials so you do not have to search for them in your account every time.
Following these steps, you can seamlessly connect to Google Drive within the ODBC API Driver, leveraging the ZappySys tool for efficient data retrieval and integration. For assistance or inquiries, contact our support team via chat on our website.
You can check our Google Drive connector article here.
