How to compress / uncompress files in SSIS using Compression Task
This guide shows you how to compress one or more files using our tool.
  • SSIS PowerPack: Download and install the ZappySys SSIS PowerPack from this site.
First, drag and drop our Compression task inside the Control Flow
Compress File(s) - Create a single archive (one for all)
Compress one or more files into a ZIP file format.
Note: This option exclusively works for ZIP format.
Compress File(s) - Create multiple archives (one for each)
Compress each file individually as a zip/gzip archive.
In this example, each file has a Gzip compression file format.
Compress Files - With folder structure
Similar to the “Compression One for All” option, compress files with the folder structure inside the Zip/Gzip file.
Uncompress File(s)
Select one or more compressed files in the corresponding format (zip/gzip), then choose the destination folder for uncompression.
These simple steps show how to compress and uncompress files efficiently using our tool. If you encounter any issues or need further assistance, please get in touch with our support chat on our website.
Need more help?
If the issue persists, contact ZappySys Support:
