How to capture web exception in SSIS JSON/XML/CSV Source
PROBLEM
If you are using JSON Source / XML Source or CSV Source and ever get an Exception that fails the component rather than Redirecting to Error Output, then you can try the settings mentioned in this article.
SOLUTION
