You may encounter the following error when querying a Linked Server:
Msg 7416, Level 16, State 2
Access to the remote server is denied because no login-mapping exists.
This can happen even when you have already configured login mapping using sp_addlinkedsrvlogin.
Root Cause
This error is often misleading.
Linked Server authentication works in two stages:
- Provider initialization
- Login mapping (
sp_addlinkedsrvlogin)
If the provider fails to initialize due to missing identity information, SQL Server never reaches the login mapping stage.
As a result:
- Mapping exists
- Connection fails
- Error message is misleading
Include User ID in the @provstr when creating the linked server.
Correct Example
EXEC sp_addlinkedserver
@server = N'MY_API_SERVICE',
@srvproduct = N'',
@provider = N'MSOLEDBSQL',
@datasrc = N'localhost,5000',
@provstr = N'Server=localhost,5000;TrustServerCertificate=Yes;User ID=MY_GATEWAY_USER;',
@catalog = N'my-data-source-name';
Keep your login mapping:
EXEC sp_addlinkedsrvlogin
@rmtsrvname = N'MY_API_SERVICE',
@useself = N'false',
@locallogin = NULL,
@rmtuser = 'MY_GATEWAY_USER',
@rmtpassword = 'MY_GATEWAY_PASSWORD';
Why This Works
| Component | Purpose |
User ID in @provstr |
Allows provider to initialize |
sp_addlinkedsrvlogin |
Supplies credentials for authentication |
Both are required in some environments.
When This Issue Occurs
Common scenarios include:
- Non-sysadmin users
- Custom providers or gateway-based connections
- SQL Server 2019 / 2022
- Using
@provstrwithout credentials - OLE DB providers such as
SQLNCLI11orMSOLEDBSQL
About @locallogin = NULL
@locallogin = NULL
This creates a default mapping for all local SQL Server logins.
Use cases:
- Quick setup
- Admin/testing environments
Recommendation:
For production systems, define explicit mappings per login.
Test Query
SELECT *
FROM OPENQUERY([MY_API_SERVICE], 'select * from your_table');
Summary
- Error 7416 is often caused by provider initialization failure
- Login mapping alone may not be sufficient
- Adding
User IDto@provstrresolves the issue
Tip
If the Linked Server works for sa but fails for other users, this is likely the cause.
Reference
ZappySys Gateway Setup Guide
