When using the ZappySys JDBC Bridge Driver, you may encounter the following error:
Error: could not open jvm.cfg
This issue occurs when the Java Virtual Machine (JVM) configuration file (jvm.cfg) is missing, corrupted, or inaccessible. The JDBC driver relies on a proper Java Runtime Environment (JRE/JDK) to initialize, so if the JVM cannot start, the driver fails to load.
Root causes
One or more of these:
- Wrong
JAVA_HOMEorPATH— points to an incomplete or mismatched directory. - Corrupt or partial JRE/JDK install — missing
jvm.cfgfile. - Mixing 32-bit and 64-bit Java binaries — e.g.,
java.exefrom System32 butjvm.cfgfrom Program Files (x86). - Leftover symbolic link (especially from older Oracle Java path shims like
C:\Program Files (x86)\Common Files\Oracle\Java\javapath). - System32 shadowing — an outdated Java copy under
C:\Windows\System32hijacks execution.
Step-by-step Fix
Step 1 — Check which Java is running
Run this in Command Prompt:
where java
You’ll likely see multiple entries like:
C:\Windows\System32\java.exe C:\Program Files\Common Files\Oracle\Java\javapath\java.exe C:\Program Files\Java\jdk-17\bin\java.exe
The first one is what Windows is actually using.
Step 2 — Test the correct one manually
Run:
"C:\Program Files\Java\jdk-17\bin\java.exe" -version
If that works fine — your install is good. The issue is with the PATH .
Step 3 — Fix your PATH
Open System Properties → Environment Variables → System Variables → Path .
- Remove any entries like:
or
C:\Windows\System32
(if it contains java.exe)
- Add your valid JDK path:
Then open a new CMD window and confirm:
java -version
Step 4 — Verify jvm.cfg exists
Go to your JDK folder, e.g.:
C:\Program Files\Java\jdk-17\jre\lib\amd64\jvm.cfg
or for newer JDKs:
C:\Program Files\Java\jdk-21\conf\jvm.cfg
If it’s missing, reinstall Java — that’s not fixable manually.
Step 5 — Clean up stray copies
Optional but recommended:
where javadel "C:\Windows\System32\java.exe"del "C:\Program Files\Common Files\Oracle\Java\javapath\java.exe"
Do this only if you verified the correct one works elsewhere.
Quick Fix Summary
| Problem | Fix |
jvm.cfg missing |
Reinstall JDK |
Wrong PATH or JAVA_HOME |
Correct to real JDK path |
| Old Oracle shim | Remove javapath entries |
| Multiple Java installs | Keep only one active version |
If you want, paste your output of:
where javaecho %JAVA_HOME%java -version
Best Practices
- Always use a 64-bit version of Java if your application (SSIS, Power BI, etc.) is 64-bit.
- Avoid manually copying Java folders.
- Keep only one active Java installation when possible.
- After upgrading Java, recheck your ZappySys JDBC Bridge Driver settings to ensure paths are still valid.
The error “Could not open jvm.cfg” while using ZappySys JDBC Bridge Driver typically indicates a missing or misconfigured Java installation. Verifying your Java environment variables, reinstalling Java.
