Question
Now, Visual Studio 2026 is the latest version, and a common question we get is whether ZappySys SSIS PowerPack is compatible with our current release. So what’s the answer to this question?
Answer
The answer is: Yes. SSIS PowerPack should work as long as Microsoft officially supports SQL Server Integration Services (SSIS) Projects in Visual Studio 2026.
ZappySys components rely on the Microsoft SSIS Designer, which is provided by the SQL Server Integration Services Projects extension in Visual Studio. As long as this designer remains compatible with Visual Studio 2026, ZappySys components will also continue to function correctly.
If Microsoft maintains and updates the SSIS designer to support newer Visual Studio versions (such as 2026 or later), ZappySys tools will remain fully compatible without requiring additional changes.
If you encounter any further issues or need additional help, please reach out to our support team via live chat or submit a support ticket at support@zappysys.com.
