Connecting Power BI with Google Calendar in ODBC
This article will guide you through connecting Power BI to the Google Calendar API using the ZappySys ODBC API Driver. By leveraging the ZappySys ODBC Google Calendar connector, you can seamlessly access and manage Google Calendar data for deeper analysis and reporting within Power BI. Whether you need to monitor file activity, analyze folder structures, or extract metadata, this integration provides a robust and flexible solution for handling your Google Calendar data.
Following the steps outlined in this guide, you will learn how to set up the connection, configure the ODBC driver, and import Google Calendar data into Power BI for enhanced reporting and data analysis.
Create/Select a Project in Google API Console:
  1. Go to the Google API Console.
  2. Click on the Project Dropdown at the top bar and either select an existing project or create a new one by clicking CREATE PROJECT.
  3. Once the project is set, click ENABLE APIS AND SERVICES.
  4. Search for Google Calendar API and enable it by clicking ENABLE.
    Enable Google Calendar API
  5. Go to the OAuth Consent Screen tab, provide the necessary details, and save.
  6. Move to the Credentials tab.
  7. Click CREATE CREDENTIALS in the top bar, choose OAuth Client ID, select Desktop App as the Application Type, and click Create to obtain your Client ID and Secret.
Create a New Driver
    ZappySys ODBC Driver - Open UI
  3. From the driver list, select ZappySys API Driver, then choose Google Calendar from the connector list and press Continue.
Google Calendar Connector Configuration
  1. Fill in the connector fields with the Client ID, Client Secret, and the necessary scopes. Then generate the token:
  2. Go to the Preview Tab, select a table, and click Preview Data to view the results. Click OK to save the configuration.
Read Google Calendar Data in Power BI using ODBC
  1. Once you open Power BI Desktop, click Get Data to retrieve data from ODBC.
  2. Search for “ODBC” in the opened window to get data from the ODBC data source.
    Search for ODBC
  3. Select the Data Source created earlier, such as GoogleCalendarDSN, and continue.
  4. You may be asked to authenticate the new DSN. Select Windows Authentication along with Use my current credentials.
  5. Select a table or view to import the data, then load it into Power BI.
  6. Finally, use the extracted Google Calendar data in a Power BI report.
Import Google Calendar Data into Power BI using SQL Query
If you prefer to import Google Calendar data using an SQL query instead of selecting a table name, you can use advanced options during the import steps. After choosing the DSN, click on Advanced options to access the SQL Query editor.
Save your credentials to avoid searching for them in your account every time.
Following these steps, you can seamlessly connect Power BI to Google Calendar using the ODBC API Driver, leveraging ZappySys tools for efficient data retrieval and integration. If you need assistance or have inquiries, please get in touch with our support team via chat on our website.
For more details, check our Google Calendar vconnector article here.
